Hello"":"\\
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
SOURCE: Nokia C3 is giving temporary
The first step is to ensure that you are subscribed to a browsing bundle. Then make sure that your internet setting are correct. The settings are a function of the mobile network with which you are connecting to the internet. You could confirm this from your mobile service operators.
If all is in order, and connection is still not taking place, then your provider network might be the fault. You can contact your mobile service providers for more assistance.
Hope this helps?
Success.
SOURCE: I have a nokia c3
It shows that the network where you are is really bad so you have to look for where the network is good inorder for you to be able to connect to ovi store and wi-fi.
SOURCE: New Nokia C3, I do
Unfortunately, your phone is designed to always have a data option. There is no way to disable the message short of purchasing a data plan. You need to be careful, as putting a sim without a data plan in a phone that is trying to use it may force the addition of a data plan to your account without your approval. Most companies make this quite clear in their terms of service. I would definitely recommend going back to your previous phone unless you want to add data.
SOURCE: hi,I recently bought me Nokia
If it is network problem then there is nothing wrong with your phone, it is the network of your service provider. Get in touch with them and put across your problem. Try using another sim and see if you are facing the same problem.. If so then take it to Nokia retailer and ask them to change the set.
Sub Menu
Terms And Conditions
Contact Us
Nokia C3-00
Select your current network to see a list of available unlocking services :
Nokia C3-00 Unlocking Instructions
Warning : Do not enter any wrong unlock
codes on your Nokia C3-00 mobile phones. If you enter over a certain
amount of wrong unlock codes on your Nokia C3-00 mobile phone, your
phone may get hard locked and sometimes become unusable.
1 - Switch ON your Nokia C3-00 with a NOT ACCEPTED SIM Card.
2 - Your phone should display 'SIM Restricted'.
3 - Press OK.
4 - Using the full qwerty keyboard, compose the code as #pw+CODE+1# and press OK.
Note :For Nokia C3-00 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Press OK.
4 - Using the full qwerty keyboard, compose the code as #pw+CODE+7# and press OK.
