When i press the power button on my nokia e71 it just boots and show the nokia and then goes back off and repeats the same thing two-three times. what can be the problem and how do i solve
Hello"::"
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
SOURCE: nokia 5610 d1 restarting during startup
its a software problem just get it software update from nokia care
SOURCE: Nokia E71 - Keyboard frozen
I too had the crazy keyboard problem. Pressed Down and New Contact would open, press S and I got DG#L ??!!!
Solution
- Essesntially you have dirt between the keyboard and the keyboard
membrane, which is causing this odd problem. Phone is still working
good a week after doing this solution.
Steps:
1 - Remove back, leave battery in place, test as you go.
2 - Use a Torx 5 /T5 screwdriver ( http://www.suntekstore.ca/t5_screwdriver_for_cell_phone_tool.html ) and remove the 4 screws
3- Depress the 4 keyboard clips, these are recessed and located between where the screws were.
4- You can now remove keyboard and front cover
5- Clean keyboard membrane (nothing aggressiv, wet a papertowl with a gentle cleaner, I used a little windex)
6- Use the keyboard membrane to operate the phone (be gentle) If it works hooray, if not curse me
7- Clean the back side of the keyboard
8- Bad news your screen will have got dust on it and so will the inside of the cover, clean them
9- Reassemble
SOURCE: I HAVE PROBLEM WITH MY MENU BUTTON nokia e71
My Nokia E71 phone menu doesn't working. can any body solve this problem?
1 - Switch on your Nokia E71 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E71.
3 - Compose #pw+CODE+1#.
4 - The Nokia E71 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E71 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E71
Each Nokia E71 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia E71 mobile phone using the form above.
