Question about Insignia IS-DVD1001 DVD Recorder/VCR
Insignia lcd tv shuts off after 2-3 seconds
Last 3 weeks when I powered on my tv it would buzz for 2-3 minutes and then the buzzing would stop...picture and volume was fine. Last 2-3 days when I power on, the tv buzzes for 2-3 seconds and then automatically shuts off? TV is roughly 4 years old and no new connections have been added. Thanks for any insight.
    New Friend:
  • 161 Answers
The TV seems to have a failing Power Supply. This could potentially be repaired but would be an out of warranty expense.
Posted on Dec 14, 2017
Anonymous
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Posted on Aug 02, 2006
DENNIS MITCHELL
  • 1003 Answers
SOURCE: 50 inch insignia plasma
THIS BRAND OF TV IS NOT REALLY RELIABLE AS IT IS ECONOMICAL YOU SEEM TO HAVE A POWER SUPPLY PROBLEM MOST LIKELY A POWER CONTROL BOARD ISSUE .
IT WILL BE MORE ECONOMICAL TO PURCHASE A BETTER BRAND NAME TV AS THE INSIGNIA BRAND PRODUCT IS ECONOMICAL PARTS ARENT AVAILABLE.
Posted on Feb 02, 2008
Chris McWethy
  • 170 Answers
SOURCE: INSIGNIA PORTABLE DVD
Use the A/V outs to the composite cable and connect to your Westinghouse A/V jacks.
On the Insignia player, press the Source button until you see A/V OUT on the insignia players screen.
Set your Westinghouse to the A/V input port you have connected the Insignia player to and VIOLA...you should have picture and sound.
Posted on Apr 17, 2008
Jaime Hernandez
  • 2337 Answers
SOURCE: Insignia LCD TV loses power
There might be faulty capacitors that are causing the intermittent power up/down. Check the 2200uF(2 per board) capacitors for bulging conditions or you can replace the entire assembly.
Let me know if you need further assistance.
Posted on Oct 06, 2008
Anonymous
  • 814 Answers
SOURCE: Insignia TV is only showing 1/2 picture
You are having problems with component failure. This could be a simple problem of over expanded solder connections that have expanded beyond the contact points on the board. This is reffered to as cold or broken solder joints. The other problem amy be actual component failure, such as bad capacitors or semi-conductor components. The unit need to serviced. You can call the Best Buy customer support telephone line at 1888-237-8289 and give them the model number of your television and the problem you are having. They should be able to give you a evalution and esimate of the repair costs. I hope this information helps you with your problem.
Posted on May 25, 2009
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/reuben_09f18ea112b9b936
Mar 04, 2016 | Televison & Video
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Starview 4 not working
reset to factory default then do a rescan that will fix it
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Insignia IS-DVD1001 DVD Recorder/VCR Logo
81 people viewed this question
Top Insignia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
