Our fisher price camera doesn't turn on....it's just completely dead. Batteries are new. I can't find a problem with it. When I plug in the usb...it shows there are no pictures in the file. Any suggestions? Thanks
wont turn on... when i plug in usb, screen comes on but nothing works
The problem is a small toggle switch inside the keyslot where the battery access door goes into. I am not sure yet why it quits getting triggered, but taking the camera apart and bypassing this swich will fix the problem. You can check to see if this is your problem without taking the camera apart by opening the access door and sticking a small screwdriver into the keyslot and flipping (gently) the little white toggle toward the back of the camera and then turning the camera on with the power button. If it comes on then the switch is your problem. I assume they put this switch in to kill power when when the access door is opened so that the camera doesn't get double power when a usb cable is plugged in (I imagine you will FRY your camera if you bypass this switch and then forget and plug in the usb without popping out the battery pack). There are eight screws that hold the cover on the back of the camera, you have to pry out those little pink pegs and then you will need a triangle bit to remove the security screws to access the inside of the camera. The two wires (red and orange) are the two that need to be connected to bypass the switch. write on the bottom of the battert pack (remove before plugging in usb) if you do this modification so you remember to remove battert power before pluggin in the usb. If you don't know what you are doing then I would suggest letting someone with some electronics experience do this.
I just had the same problem. I have read all the troubleshooting guides to try and fix it. I got frustrated and did it myself. Try unlocking the door and hold the power button down as you lock it back. After trying this my sons camera turned right on. I hope this helps someone else.
Try this. there is actually another battery inside the camera. open the door on bottom of camera and then take out the 4 AAs. then unscrew the smaller screw and slide out the drawer-- replace the CR2032. screw everything back into place and voila. back in business. have had this camera for 5 yrs and this is first time i had to do it.
Make sure the door is closed all the way. use a phillips screwdriver to turn the lock (even though it is possible to close with your fingers). Closing the door all the way clicks that white toggle that someone else mentioned into place. our camera works just fine after many frustrating attempts to fix it!
Camera won't turn on -- new batteries -- when usb is plugged in LCD screen comes on, but camera will not operate any other way
same problem here, new batteries and no reaction on pressing all of the buttons.
has nayone figuredout the colution to this prob yet?
Brand new and won't turn on. It's as if there are no batteries in it but we have switched out three different sets of brand new batteries.
there are 3 orange wires, and if you know which ones, which ends do you connect? I tried this and picked the orange that connected to the letters bat on the green board. There was no change
I have 2 of these camaras thjat were left outside and don't turn on now
Our son's camera is having the same problem. It acts like there are no batteries in the camera at all. I took the sugestion of testing the white switch inside and it still won't turn on. VERY DISAPOINTED! Fisher-Price is suppose to have great products. My 3 year old was upset when he got it for his birthday and now it's nothing but trash.
wont turn on
My daughter too is facing the same problem. replaced batteries twice. It switches on only for 2-3 seconds and then dies off. what to do? Ananth from Mysore, India
