At first, my USB disk works well, when suddenly it asked me to reformat the disk, I clicked yes and when I checked the memory, from 4gb, it was changed to 4mb!!! I really freaked out and used a lot of applications like Disk Management & Cmd and nothing worked. Please help me.. :-(
You may try diskpart to restore it back to full capacity. How to Fix Your USB Pen Drive when it Showing Less GB Disk Space
SOURCE: my 4gb microSd sandisk is infected and cannot be
It supposes to have a tiny lock/switch on the side. Move it up or down to turn off/on the write protection.
SOURCE: Please insert a disk into Drive E
Transcend provides a online recovery tool.just download that and format your pendrive with it.....that will solve your problem 100%.....
SOURCE: I have an 8gb maxell usb memory stick which asks
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
SOURCE: My SanDisk Cruzer Gator 4GB is not working. When
The filesystem appears to be corrupted. Try right-clicking the drive's icon, going to Properties, Tools and Check Disk. If that doesn't help the partition that holds the data may be unreadable, and if that happens try asking a data recovery service if the data is important.
