Apple iPhone Smartphone Logo
Posted on Jan 25, 2009
I have an orange sim card with all my contacts but when i put it in the iphone, it doesn't let me view any of them
jdmulcahy
Level 1:
  • Contributor 34 Answers
  • Posted on Jan 26, 2009
jdmulcahy
Contributor
Level 1:
Answers
34
Questions
0
Helped
14846
Points
74
What carrier is that sim from? anyway if you put that sim into the iphone there is an option to import sim card contacts through settings. go to: settings, mail contacts and calendars, scroll down to the bottom and press the import contacts button. i will warn you that this does not always work.
I want to transfer contacts from iphone a1303 set to sim
Actually, iPhone doesn't support to save contacts to SIM card. However, you can still reach this aim with the help of an Android phone. Just follow the below steps.
Step 1. Go to the Contacts app on your iPhone, find those contacts you would like to transfer to SIM card. Then tap "Share Contact" and share these contacts via email.
Step 2. Download the vCards you just shared via email on your Android phone. Go to Contacts app on Android phone, then you can choose "Import from USB storage".
Step 3. Go to Contacts app to check if contacts have already been imported to your Android phone. Then go back to "Import/Export contacts" again, this time you should tap "Export to SIM card". Of course you need to put the SIM card into the Android phone before this step.
With this way, you can copy a limited number of contacts from iPhone to SIM card. This isn't a direct and simple way to transfer iPhone contacts to SIM card. You need the extra help of an Android phone, and you also need to type emails one by one to import SIM contacts. Although, it is a good way to back up the contacts by coping them to SIM card, you can also use other backup methods to save the contacts, like use data backup programs or back up them to the cloud.
For more details, check: How to Transfer Contacts from iPhone to SIM
Oct 10, 2017 • Cell Phones
How do I save my contacts to sim? I can't find the copy all function.
Apple won't allow to save data into SIM with iPhone. However, you still can reach this aim through certain indirect methods. Just follow below steps.
This can be a good way if you only need to transfer a few number of iPhone contacts to SIM card. You can do this by sending emails of the contacts. You can email the contacts one by one to your Android smart phone, and then import them to the SIM card in the Android phones. The detailed steps may better help you.
For more methods, check: How to Transfer Contacts from iPhone to SIM
Trnsfer contacts to sim iphone 4
As a matter of fact, iPhone won't save contacts to SIM card. However, you can utilize an Android phone to finish this task. Just follow below steps.
I need to know how to transfer contacts from Telstra t90 std sim to apple iphone 5 micro sim
Actually, iPhone won't allow exporting contact to SIM card. So you have to reach this aim with the help of Android phone. Just follow below steps.
2answers
Transfer contcs from a blackberry curve9350 to apple 3gs
u cant transfer it directly but u can transfer them to outlook and when u connect ur iphone to the pc u can choose to sync the contacts with outlook.
good luck
Ive got an iphone 3G and ive got an orange sim card, ive come to put the sim card in the iphone but there is know were to put it.
this is where to find your sim tray on the phone if you dont have the sim eject tool just use a folded out paper clip
How do i access or copy my sim contacts from the sim to the phone?
Actually, you can import contacts from SIM to iPhone with simple steps. Just follow below guide.
iPhone doesn't store contacts on the SIM card. If you want to transfer contacts between iPhones, you can use iCloud to backup or transfer content between devices. When it comes to import contacts from SIM card to iPhone, users will only need three simple steps.
  1. Remove the SIM card from the old phone, and install it on your iPhone.
  2. Your iPhone may need to reactivate. If so, connect to iTunes.
  3. Tap Settings > Mail, Contacts, Calendars > Import SIM Contacts.
  4. Wait for the import to complete.
  5. If you swapped SIM cards in step 1, remove the SIM card and replace it with your iPhone SIM card.
  6. Open Contacts and make sure that the contacts imported.
The contact information imported from a SIM card depends on how your previous phone stored information on the SIM card. For more help with importing contacts from a non-Apple phone, check the manufacturer's website, app store, or contact your carrier.After doing this, you will get the contacts in your iPhone. Transferring contacts from SIM card to iPhone is easy to be done when users have a suitable SIM card with iPhone. But if the SIM card cannot be recognized by iPhone, what should the users do to import contacts from SIM card to iPhone?
For more details, check: How to Transfer Contacts from SIM Card to iPhone
2answers
Ii got a unlocked iphone had signal for the first hur or too now has none even tho it says orange has no bars and cant txt or call or recive
Reset the iPhone:
It has been observed that simply resetting the iPhone can resolve signal strength issues.
Reset network settings:
In some cases resetting the network settings has also helped so tap Settings, tap General, tap Reset, tap Reset Network Settings.
This will restart your iPhone and will also delete any stored Wi-Fi passwords as well as DNS settings and more.
Place your SIM card again:
If your iPhone’s SIM card is not placed properly, it has been observed that it can affect signal strength.
So a good idea would be to remove your iPhone's SIM card by pushing a straightened paper clip into the small hole on the top of the device to open the SIM tray, then check for debris inside the tray or SIM card slot, remove it by blowing into the slot or using compressed air and then placing the SIM card properly and then re-inserting the SIM tray.
The notion is that improper SIM contact can result in a weak signal, so the above procedure could help.
Attaching scotch tape to the SIM card:
This is indeed the most ingenious methods, it appears that attaching a small piece of scotch tape to the outer side of the iPhone’s SIM card (the side of the SIM card that does not have metal contacts) can result in a surprising boost again borrowing from the notion that improper SIM contact can result in a weak signal.
46helpful
13answers
Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
