I unscrewed the pin trap, cleaned out all the coins, and now I can not screw the pin trap back into the washer. No matter how hard I push the pin trap it won't slid all the way in. There doesn't look to be anything blocking the groves that the pin trap slides in to. Any tips? Thanks in advance.
SOURCE: Cleaning the Pin Trap
You have coins etc stuck in it you will need to force the pin trap out you can buy a new one
SOURCE: Asko 6221 washer. push
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Thanks for your post, friend!
I understand that you looking for steps on how to clean the coin trap on your Frigidaire washer. Here are the steps to access the coin trap.
· Assure power has been disconnected to your appliance.
· Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure it is tilted up safely.
· Look inside on the bottom right hand side there is a black accordion piece. This is the screen trap or coin trap.
· Have towels available with you because any access water will come out.
· At the top of the coin trap where it is attached to the drum you will notice a silver spring and screw. Loosen the screw and wiggle the coin trap out.
· Clean the trap and follow these steps in reverse to reassemble your washer.
Best of luck! -Matt
AFFINITY COIN TRAP
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion piece. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
6. Reach inside the coin trap and clean what is inside of it out.
7. Put the unit back together following the same steps backwards
1. Unplug the unit.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
If proves to be ineffective contact a professional to move forward accurately.
Hello - After further researching it does not seem that there is an actual diagram available. However you may try the following steps to clean out the coin trap on an Affinity washer. Please be very cautious and it is actually recommended for this to be done by an actual certified technician.
1. Unplug the unit.
1. Unplug the unit.
out.
