My coby kyros mid7048 tablet's camera is not working. it gives me an error saying: "unfortunately, camera has stopped." how can i fix this? I was able to use it for one week and them suddenly it stopped working. it goes to the camera interface but shows an error when i try to snap a picture
SOURCE: my coby kyros won't turn
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
SOURCE: I purchased the coby kyros internet tablet from
Hi! As a first course of action, I strongly suggest that you look via internet for the driver. Hope this helps and thank you for using FixYa!
SOURCE: can i download kindle to
You need AppsLib on your tablet (you can download from them), and from there you can search for third party readers (I dont think you can get kindle as its designed for phones). Android tablets dont have access to the android market place therefore tablet manufacters have their own - in this case AppsLib.
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
SOURCE: How to clear internet history on coby kyros
Go to your url box and click the bookmark button, choose history, press the menu button above your tablet, the one beside the home button. A clear history option will pop out, press it and your whole history will be erased. Hope this helps. :)
