Switch is broken and trying to get it running how can i make it run with out getting a switch
SOURCE: I have a 1981 Honda CT110 Trail 2 wheel
The problem is an air leak leaning the fuel mix. The idle speed starts going up a ramp until it is wide open. The valves no longer seating well is a possible cause as is carb manifold gaskets, rings and a cylinder head not torqued down tight.
SOURCE: idle is high and kill switch wont turn off its a 1999 tho
TURN THE IDLE ADJUSTING SCREW ON THE CARB.
SOURCE: 88 honda ct110 6 volt system. 8 volts at headlight
sounds like the new used one is bad too. The only thing that regulates voltage is the rectifier.
SOURCE: ct110 honda will not stay running with out the
Disassemble the carb and clean it. Soak the parts in denatured alcohol for 30 minutes. Home Depot and any hardware store has it. Now use spray carb cleaner from the auto parts store to finish the cleaning. Be sure to spray into all the little holes (fuel circuits) and into the throttle and air screw holes as well. Put both the throttle and air screws back where they came from and screw them in until they LIGHTLY seat. Now turn each of them outward one and one half turns. This is the factory setting. Also clean the air filter and install a new spark plug ( NGK DR8ES-L ). Check the rubber O-rings on the intake manifold and replace them if hard, cracked, cut or abraded. You can order the parts from www.babbittsonline.com/parts/viewbybrand/parts.aspx This site will show an exploded view of the entire motorcycle. Please rate my answer. Thanks.
SOURCE: i have a 1986 honda shadow vt 1100 c it runs good
Fuel pump relay...had this problem a couple years ago. It's used for if the bike tips over, it kills the fuel pump. You can bypass this or find a used relay. New ones are discontinued. It shows in the Honda service manual for that year how to bypass the relay to test the fuel pump. In your case it's to test to see if the relay is the cause of it dying...mine would die and then not start for some time...then it would start as if nothing was wrong until it happened again. Good luck.
