Samsung Series 7 Chronos Logo
Anonymous Posted on Jan 15, 2013
Can't eject cd from drive in samsung chronos windows 8 version
Can't locate disc drive to eject. disc is not being read
Khurram Shah
Level 3:
  • Master 10,322 Answers
  • Posted on Jan 29, 2013
Khurram Shah
Master
Level 3:
Answers
10322
Questions
0
Helped
1468217
Points
20233
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
How is open the cd room
Bad eject button. If you are running Microsoft Windows, openMy computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
CD-ROM, DVD, or other disc tray not opening. - Computer Hope
www.computerhope.com/issues/ch000214.htm https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=how+to+open+the+cd+rom
Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
I hope this helps.
Drive Reads & writes CDs but only reads DVDs. Attempts to write a DVD ejects the disc with a 'insert writable media' prompt. Device manager says driver 'up to date'. Am I using the...
my desktop computer will not write to a dvd, but will play a dvd
& my laptop will play a cd but will only write to a dvd
it's just the way the drives are,,I've tried different types of dvd also nothing helped
2answers
I HAVE A PRODUCT KEY AND WANT TO DOWNLOAD IT TO THIS COMPUTER BUT THE DISC ISN'T WORKING
you need to do a lot of test, 1. check in bios if your cd-drive or dvd- drive is in enable if not enable it. 2. if your cd drive was enable, try to insert another cd, if the cd you insert was read by cd- drive, the problem is your cd. then if the other cd you insert is also din't work the problem is the cd-drive or dvd- drive. :P
Samsung notebook states cannot start as windows file missing and to use disc to repair, however as it is a note book there is no disc drive or disc.
You need a repair/reset CD, and you may need an USB external drive to read it if yours doesn't work or isn't available. The CD may be obtained by Samsung tech support. For Windows XP and Vista you just select OS installation and hit 'R' for repair.
Alternatively you can note down the name of the missing file, locate and save it on a USB key from a computer with the same OS version, and boot the PC using Universal Boot CD (UBCD). Then just copy the file where it should be. Unless you're short a specific driver or VXD, most other files are drop-in compatible.
2answers
How do i transfer files from a disc to my computer. I have put the cd disc into the cd tray but nothing came up on the monitor
Depends on your your operating system but assuming you are using a version of windows you need to find My computer. This will open a window where you can see your hard drives & CD/DVD drives. Right click the CD drive you want to access and then click "Explore" or "Open" depending on your version of windows. Provided the disc is not damage this will allow you to view the content of the disc & drag it to a folder on your PC.
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
