The washer leaks near the front of the washer. All the hoses going and coming from the washer do not leak. What can be the problem. We do not have the manual. My kenmore washer is leaking after spin cycle, lower front....any idea what's wrong?
SOURCE: top load kenmore 110
This is commonly caused by a leaking water pump, or the hoses attached to the pump. The following link explains how to access the interior of the washer to inspect for leaks:
http://www.fixya.com/support/r397092-replacing_water_pump
This link explains how to replace the water pump if that is the case. Keep in mind, these pumps are sealed units and are not serviceable. If the pump is leaking, or not functioning, it needs to be replaced. in addition, double check all hose connections to the pump (there usually two hoses) and make sure there are no cracks or holes. Make sure the hose clamps are secured properly. I hope this helps you. Let me know if you require additional assistance.
leak all the sudden in my front loaf kenmore washer and dryer - they are on top of eachother. All hoses in bakc frin - so leak coming from bottom right when washer strats to churn. Slow leak
