Frequent PE errors that seem to be related to an unbalanced load. The error can be reset by removing the plug from receptecle waiting for 10 minutes w/o power. The plug is placed back into receptacle while holding the power button for 5 seconds then open door rotate the wash drum to finish cycle. The washer seems to be experienceing this error more frequently.
SOURCE: LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
SOURCE: LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
SOURCE: LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
SOURCE: TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
