Booklet says "Don't change the hour of the day or date during specific hours" PDF download on the site is the wrong information for setting the date! contraidiction? Since Christmas I have had this watch (3 hand watch/No month/Only date) And I have been trying to get the correct time change since december 25th! No help from the company/replies/nothing. Still having problems that no one can explain. All I want is for the date on my watch to slowly start turning to the next day a bit before midnight & it slowly starts turning to the next date at 2 am.i don't know what to do. I'm lost. Does anyone know anything about this or ever even heard of this?
Turn it 12 hours forwards or 12 hours backwards that will correct it to the right date change
Thank you for your reply. I thought that was what the problem was. I just brought it into 2 different watch stores & they believe that when the watch was assembled the hands were set incorrectly. They said the date on the watch should start to change at around a quarter to 11 & by twelve it will be the correct date. The date on this watch changes exactly 1:47am. Very strange. I called the manufacturer & they said they can replace it. Thank you for trying to help!!!
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
SOURCE: date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
SOURCE: changing settings
I just purched a new Kennith Cole watch I am unable to set the three didget date at the top ...any help
SOURCE: Casio 3747 Wave Ceptor is 3 hours 52 minutes behind...
Paste this link into your browser and download pdf file:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3747.pdf
Read carefully about Radio-controled time keeping and other related chapters.
If after performing all the required operations your watch still does not work properly, you have some kind of fault in the Integrated Circuitboard and will need to seek for watchmakers help- probably an IC replacement.
Do not forget to rate, please.
SOURCE: Hi, I just purchased an
Pull crown out 1/2 way to fist click. Rotate one direction for date and the other direction for day. Should be clockwise (right) for day and counterclockwise (left) for date.
