Put the machine on to wash and started OK. Later went back to find it stopped with WASH light on and DOOR LOCKED light flashing.
Door was closed and locked, had to unplug to release door lock. Now when I try to put machine on, the door locks but the machine does not recognise that the door is closed/locked (door locked light off) and the machine will not run.
Is this a door interlock problem, or a failed electronics board? If door interlock, how tricky is it to replace?
Thanks.
Replacing is not too difficult. remove the door seal retainer on the front of the machine, should be a wire and spring affair, and slide the door seal away near the lock.
undo the two screws holding the lock on and swop the connector into the new one.
put some washing up liquid on the retainer before putting it back on to make it easier.
