Question about Bosch WFLI 2440 Front Load Washer
Bosch wfl12440 has red light flashing and wont go ont spin
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Anonymous
  • 57 Answers
SOURCE: Bosch WFO2865GB that stops before the Spin cycle
probably not draining fast enough, check for blockages at filter, sump, outlet and plumbing
Posted on Mar 30, 2010
john_cross
  • 6277 Answers
SOURCE: all spin lights are flashing and washer wont
(I cannot type this fast- it's pre-typed and no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it ยท Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
Mar 29, 2010 | Bosch Washing Machines
My washing machine won't turn or spin.
ok on the bottom there is a donut looking connector with holes and it needs replaced unless its belt drivin
Aug 14, 2009 | Washing Machines
Stopped spinning red light flickering on spin
Motor problems, or transmisstion is slipping, still a major problem.
Aug 10, 2009 | Bosch Washing Machines
Red lights flashing on ViewSonic PJ750
This is a sign of overheating, its a thermal issue, I solved the problem with some compressed air, but absolutely DO NOT blow in the ldc assembly or you will get dust in the lens system. You want to blow the cmpresed air on the electronics not ont he optics. I found that over time dust hair ect collected on the thermosistor and caused the over temp error. Cleaning it resolved the issue.
Feb 26, 2009 | ViewSonic PJ750 Multimedia Projector
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Bosch washing machine flashing red lights
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch WFLI 2440 Front Load Washer Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
