"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The mark of the DC motor and control board should be matched connected. Sometimes you alsoneed to check the wires of the motor and restart the whole treadmill again
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer. Repairing 04 Error on Bosch Washer
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The mark of the DC motor and control board should be matched connected. Sometimes you also test the wires from motor, and restart again the machine and proof. God bless you
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The mark of the DC motor and control board should be matched connected. Sometimes you also check the wires of motor, and restart the machine complete.see the diagram attached God bless you
please proceed according and fix it. See the diagram for troubleshooting and see my personal TIPS for motor help. "E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The mark of the DC motor and control board should be matched connected. Sometimes you also test the wires from motor and restart the treadmill
Lisa,
E04 is an error code which shows that one or both of the reels has stopped during play or record operation. We find that tapes with liquid contamination can stick to internal parts in the mechanism causing this error. Try another tape, if this does not resolve the problem something is defective in the tape transport.
Good Luck to you!
Joe Weibel
customelectronics.org
