Are you using that camera for several years? first try to replace the battery with a new battery, if the problem goes again, open the camera by unlocking the screws and clean the lens with a soft cotton or clean cloth, and then turn the camera again. if the problem is still the same, resolder the small circuit that drives the camera lens, or that is connected to the camera lens by using a soldering iron 30 watts, but first turn off the camera. then turn the camera again. see if this one's works, if you don't know how to do one of these things. just have your camera repair by a professional technician. the repair cost isn't big enough. thnks,
Have a nice day ahead
I have to Agree with the Comment above that you Put. There are a Great number of Better Cheaper Cameras on the Market right now. I would keep the One that you have, Get a New one and repair that one Later when you have the Funds for it.
Sorry to say my fuji has the same problem I called a camera store and they told me it would cost around 250.00 to repair. The part the wint wrong is the gears for the shutter striped or got jambed up. So I junked it and bout a new camera. If you think it is worth 250 to repair the get it repaired.
I had the same problem with my S5600 too. It broke down after using it for only 4 months. It's really frustrating. I tried changing batteries and resetting the camera but it didn't work. I bought the camer from the UK, and I don't have international warranty support here. The local Fuji repair center said it would cost about $145 to fix, almost two thirds the price of a new S5600. I belive its not worth fixing.
Tap the sides of the cammera.also can be the problem of faulty battery.insert new camera and check out.
for reparing estimates cost of camera
http://www.advancecamera.com/repair
Maybe its stuck up or jammed open the assembly and clean wether it moves properly.
Yes its worth reparing.its can be the assemly getting blocked problem.get it repaired. thanks
I need to know if the cost of repairing my FUJI F10 camera will be excessive or should I consider purchasing a new camera. My previous respnse from Fixya just said to go ahead and repair. With the high costs of repairs and the low cost of better, newer cameras, I'm not sure what to do?
I am disappointed with the help from your two "professionals" and feel that unless I recieve a further more informative response, I will have completely wasted my money. I await your reply.
