As the bowl cannot turn freely, the machine won't spin. With out the rotor on, the shaft turns ok. Put the rotor back on and turn it and it gets slightly stuck with a bit more turning pressure it will continue to turn.
SOURCE: F&P Smart Drive #703 trouble
possible outer casing out of alinment, try lining up while doing up the bolts. Regards Engineer
SOURCE: machine not filling with hot water
First check the filters in the inlet hose and hot water pressure. Sounds to me like the hot water valve is faulty. Test the w/machine on a hot water cycle, if you hear a noise and its not filling it up with water,its a faulty hot water valve. Air pressure?? change the water valve and remember it has a little rubber boot on the old water valve, transfer this to the new valve,or go into option adjustment mode and change you wash temperature settings.
SOURCE: washing machine wont fill with hot water
if you pull the filter out of you (hot water) valve with a pair of long nose pliers you will see a black rubber seal. pull this rubber ring put as it acts like a restrictor.
SOURCE: Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
SOURCE: Something is stuck underneath the
Hi - with aquasmarts there is a plastic dome like fitting in the middle of the agitator & unscrew this to remove the unit.
Hi
F2 error is displayed when control won't sense motor to be
rotating, usually occurs due to frozen/bad motor or stuck motor rotor or the
RPS sensor or a bad stator assembly. If the motor rotor spins freely and both
impellers are securely attached then the issue is with the RPS sensor. If the
motor won't rotate then it is the motor rotor that has to be replaced. Hope
this helps...please post back for further assistance.
Daniel
