Canon Pixma MP450 All-In-One InkJet Printer Logo
Posted on Jan 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CANON PIXMA ERROR 5800
WHAT IS THE PROBLEM AND HOW DO I FIX IT?
Anonymous
Level 3:
President:
  • Master 2,559 Answers
  • Posted on Jan 28, 2009
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1213544
Points
9283
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Jan 20, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3090517
Points
19604
Hi and welcome to FixYa,
Your described problem with a Canon Pixma MP450 indicates that the absorbent material that takes in the waste ink could no longer absorb further anymore waste ink. The waste ink if a result of cartridge/head initiation and most often when cleaning is done.
Corrective action is of course replacement of the waste ink pad. Although the reset procedure could be performed to 'trick' the printer to think that it was replaced. Steps involve are:
  1. You will turn off printer.
  2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
  3. you will let go button Resume/Cancel, continuing to retain POWER.
  4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
  5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
  6. you will turn off printer by button POWER.
Goodluck and thank you for using FixYa.
Ginko
Level 3:
  • Canon Master 19,396 Answers
Ginko
Canon Master
Level 3:
Answers
19396
Questions
25
Helped
8077680
Points
55462
gerrytheboss6767
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Canon Expert 55 Answers
  • Posted on Dec 01, 2018
gerrytheboss6767
Canon Expert
Level 2:
New Friend:
Greenhorn:
Answers
55
Questions
0
Helped
79081
Points
166
Customer care support service number +1--833--{272}....[0777],,,,,,call them
Anonymous
Level 3:
  • Master 679 Answers
Anonymous
Master
Level 3:
Answers
679
Questions
0
Helped
348657
Points
1860
1 press menu2 PRESS scan copy scan to enter service mode
3 use > to go to NVRAM ACCESS
4 set ABS-M LEVEL TO 0
5 Set ABS P LEVEL TO 0
6 Set press STOP to EXIT
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607738
Points
3590
Its a waste ink error
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Jan 20, 2009
    follow these steps
    2) Enter NVRAM by presing <--- or ---> then OK
    4)OK
    Canon Waste Ink Tank Reset Procedures
    try this
    Discharge of the code 5100
    1. Turn off printer.
    2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color.
    3. let go button Stop/Reset, continuing to hold POWER.
    4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons.
    5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key)
    6.turn off printer by POWER button, then turn on.
    7. You should be set. If it didn't work, try it again, slowly. It WILL work!
    hope this helps
Ekse
Level 3:
  • Canon Master 13,435 Answers
Ekse
Canon Master
Level 3:
Answers
13435
Questions
82
Helped
3985071
Points
38023
Waste ink absorber is full
the waste ink tank needs to be cleaned or replaced and then the printer needs the counter reset.
reset instructions
http://www.fixyourownprinter.com/forums/printer/52461
Anonymous
Level 3:
President:
  • Master 1,990 Answers
Anonymous
Master
Level 3:
President:
Answers
1990
Questions
Helped
910016
Points
6127
Welcome to Fixya! Try this. Unplug all Cables and Power from the Printer. Uninstall and Reinstall Printer Software, Restart your PC, Reinstall your Cables and Power, Run Software and Print a Test Page. Let me know where you are at then.
3 Related Answers
Robert Kitaji
  • 1335 Answers
  • Posted on Dec 19, 2009
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
A
Anonymous
  • Posted on Apr 30, 2008
SOURCE: Error 5800: waste ink
Clean or replace the absorber and reset the printer counter to clear the message.
Anonymous
  • Posted on Mar 17, 2009
SOURCE: canon printer pixma mp110
My Pixma MP110 keep on displaying "CHECK PRINTER (5800)" Please have m to solve this problem
How can I Fix Canon Error Code 5800?
Solutions to Fix Canon Printer Error Code 5800
  1. Solution 1:- Replace the Waste Ink Absorber. ...
  2. Step 1:- Press the "Power" Button. ...
  3. Step 2:- Press the "Stop/Reset" Button. ...
  4. Step 3:- Move Into a Service Mode. ...
  5. Step 4:- Press "Stop/Reset" Button. ...
  6. Step 5:- Turn On Canon Printer. ...
  7. Solution 2:- Enter Canon Printer In Service Mode.
https://www.canonprintersupport247.com/blog/fix-canon-printer-error-code-5800/
1helpful
2answers
What does printer error code 5800 mean?
This is an ink overuse error. It may read 5B00 and not 5800.
No real easy fix as far as I know but this video might help. Good luck! https://www.youtube.com/watch?v=0waX_GF-h7U
This video might help
2helpful
My Canon MX700 has 5800 error. How do I fix it?
you might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similar options also you can troubleshoot the device
hope this helps you
8helpful
2answers
Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
63helpful
3answers
Canon MX 308
How to reset canon MX 308 ??
Error Code 5800
Any Software to reseter this printer?
3helpful
3answers
Error (5800)
Waste ink is full counter reset.
23helpful
5answers
Canon printer pixma mp110
how can i reset canon pixma mp 110 tahnk you please help me
old marine
old marine
ZJ Limited
ZJ Limited
