Part no.700r
There are parts and part number listed on page 20 of the manual. Here is the link for the Ryobi 700R trimmer manual.
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
SOURCE: I am looking for a manual for a Ryobi 700r
Gday,
Just check out :
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Have fun :-)
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
Testimonial: "Thank you! Just what I needed."
SOURCE: I need to know the fuel-oil ratio/mix for my Ryobi
Start with 40:1. If it smokes, go to 50:1. Good luck...Lee
SOURCE: I have a Ryobi 700R trimmer - I need to know how
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case:
1. Disconnect the shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts).
3. Pull the cord until the stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
Use proper line and reverse for new line. Good luck!
