Can't instal the drivers on my laptop. OS: Windows 7 64-bit
This appears to be a very old device that was intended for use with Windows XP:
https://media63.music-group.com/media/sys_master/h46/h33/8849495293982.pdf
I suspect that the software is incompatible with Windows 7.
SOURCE: Behringer F-CONTROL AUDIO... Problem:
I had a similar problem where as I could use the mic no problem at all but couldn't hear anything through the headphones. The simple solution was to disable the driver for my internal soundcard. It took me 48 hours to work it out! Good luck.
SOURCE: driver
bagaimana cara download driver untuk komputer celeron reltek ALC 101 VGA:VIA P4M266?sekaligus dengan nama web sitenya! terima kasih
SOURCE: control panel not showing up, doesn't appear in sound control pan
i want to use driver of blackberry8700..how can be use it..
SOURCE: Is there a specific driver to Behringer Audio
http://www.behringer.de/EN/Support/Register.aspx
have you tired to register and ask the manufacturer
SOURCE: I have upgraded from Win
Try uninstalling the hardware, and then reinstall using the software downloaded from Behringer, rather than plug and play.
