I ordered one online and the wheel which takes in the paper was separated from the printer when I opened it.
SOURCE: Canon Pixma Printer
Unload all paper. Examine the feed track for any obstruction- paper fragment - cookie crumbs. Take a vacuum nozzle to it and give it a good suck out. Now feed a heavy weight paper/thin card through. Did it do the trick?
SOURCE: Canon MP 160
I had the same problem with my mp 160, I tried to print but the printer only took the left side of the page and the paper got jammed. I pulled it out but I think a piece was left inside the printer. Error message was blinking, but somehow I got the printer moving again. I tried to print again, but this time the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbore(I used a magazine cover), cut it in a shape of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine.
SOURCE: how to open canon pixma mp 610 printer to remove
The paper is blocked
Give me please a solution
Thank you
SOURCE: canon pixma ip1200
also i lost cd set up printer pixma ip1200
looking here to solve and nobody give me answer
SOURCE: Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Testimonial: "Thank you,I did replace the USB cable and all is well."
