Kenmore 24932 Top Load Washer Logo
Posted on Jan 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washing machine will not spin or agitate
I have a 9 year old kenmore 70 series top load washing machine, model 110.20702.990, that will not spin or agitate
Paul
Level 2:
Sergeant:
  • Expert 225 Answers
  • Posted on Jan 20, 2009
Paul
Expert
Level 2:
Sergeant:
Answers
225
Questions
0
Helped
69709
Points
512
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Kenmore 70 series washer model 22722 will not spin or agitate
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
1helpful
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
2helpful
My kenmore washer 70 series model 20712 990 will not agitate or spin. it drains, but won't agitate or spin. what is the problem?
This model has a safety switch in the door switch. This switch goes bad and the machine will not spin or agitate. Have that replaced and you will be back in business. Hope this helped you out. Good luck.
11helpful
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore series 70 model 24732
check the lid switch. that is the most common problem if not spinning.
tnx 4 using fixya,
drcool
84helpful
8answers
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Alexander
vince
