HEWLETT-PACKARD HP G71075DX Pavilion Laptop AMD Phenom II Processor 173 LED HD Display 4GB DDR3 Memory 50 Logo
Posted on Jan 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an HP Pavilion G7 that I've had for about 15 months. After about 6 months the web cam stopped working. Then about 2 months later 1 USB port stopped working, followed by a second not working
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 71 Answers
  • Posted on Jan 04, 2013
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
71
Questions
0
Helped
10074
Points
176
May be your moterboard fault.
  • 1 more comment
  • Anonymous Sep 22, 2021
    bull snort.
  • Anonymous Mar 05, 2022
    wrong OS running , not one clue what OS you do run but is wrong
    or failed to ask HP for driver that make USB work
    many PCs all fall with w8 installed and up[. lacking USB drivers.
    the cam uses secret internal USB-0 port
    deep inside PC, so is first to fail.
    as is the webcam driver wrong.
    folks upgrade the PC OS and fails
    or reloads the OS from scratch and then forgot to get the huge HP.com driver set for this exact PC, not told G7 is series.
    and exact OS not told.
    I will pretend you said, HP Pavilion G7-1158nr
    and w8 drivers.(max os )
    w8 has less drivers, there.
    https://support.hp.com/us-en/drivers/sel...
    first see if Plug and play works
    in control panel
    tell w7? to update cam and usb
    be internet connected.
    if still fail
    get the drives at HP.com
    they are there still.
    test the camera with no usb ports or cables connected, at all but a keyboard.
    cables can and do short.
    then test all usb ports using mouse
    or usb keyboard, wired, are they all dead.? still?\
    the USB ports in laptops share power
    some times 4 ports are shared.
    so if one shorts out, cables or devices
    they all go dead at once.
    the PC has 3 USB slots. + usb0 inside,
    so you only tested 2 of 3? why not all
    best test on earth is usb keyboard wired.
    all other ports not used.
    to reasons to fail
    OS upgrades done wrong
    USB devices shorted test them 1 at a time and never just 1, if its bad it makes the test useless.
    when posting on PC tell full model number
    not near useless G7 name.
    tell what OS is there now.
    tell if OS was upgraded or fresh installed .
    tell if changed from w7 to w8.
    tell how if did. if USB fails driver are bad. in most cases./
3 Related Answers
davidmamian
Davit Mamyan
  • 552 Answers
  • Posted on Jun 11, 2011
SOURCE: hi Im having a problem with
scan with strong antivirus your pc, then use programm cc clenaer , there is registry fixer, you can fix all reg. errors.
Anonymous
  • 1833 Answers
  • Posted on Jul 29, 2011
SOURCE: it will not start.
There are several things that you should check: 1. Remove the ram and start the laptop: check if you hearany beeps. If thereis no beep sound, then it either the processor or the motherboard are bad. 2. In this situation check the AC adapter. You can test theoutput voltage with a voltmeter. If you cannot do that, find a known good ACadapter and use it for testing the laptop. It is possible the laptop appears tobe dead because the AC adapter is bad (and the battery is discharged). If youknow that the AC adapter is working properly and it outputs correct voltage butthe laptop is still dead, most likely you have a power issue on the motherboard(or power board on some laptops) and it has to be replaced. 3. Remove the memory module and install it in another slot. Hope this will help you. Good Luck.
Anonymous
  • 32281 Answers
  • Posted on Aug 10, 2011
SOURCE: While charging on AC works absolutely fine. But
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mediasmart webcam is not working on my HP Pavilion dv6 laptop. I went to device manager and it said that it's working properly. I've tried opening it through websites, and it crashes. When I open...
NO OS stated, XP you know its dead right if XP, why not tell ?
help near impossible lacking that key fact
what cam , the one built in?
the USB ports must work on HP or the cam will fail.
no many HP laptops, yeah, 2 drivers just work the USB port and cam both.
What OS?
the drivers are at HP.
run the HP assistant yet.http://h18021.www1.hp.com/helpandsupport/hp-self-support.html
load the drivers yet, from HP and nobody else
oops its retired now, legacy.
no support page, try the assistant and pray.
finding drivers for old PC is getting hard with this silly 10 year rule.
there is a hard way to get them.
lots of steps, ask.
My laptop HP Pavilion dv6565us, suddenly webcam stopped working, it says web cam not connected recently i down loaded yahoo messenger 10
Your downloaded file of Yahoo Messenger 10 could have a virus on it which tells the computer something in the port you are using is not connected. Try a different usb port on your computer, Or your webcam could've just died. My webcam died after 1 week of use.(Labtec webcam) I would suggest trying different ports, Un-installing and re-installing, or purchase of a new webcam
Hope this helps. Please don't forget to rate. Thanks ^^
1helpful
I have a HP webcam I want to install on my Dell Vostro 1000 laptop. How do I install it?
Dear Sir,
Here is the Solution
1.connect the web cam to the Dell Vostro USB port
2.Install the drivers using HP Web Cam Driver and Application CD.
3.Restart the laptop.
Now web cam is ready for use.
good luck
Fixya Customer Support
Chandrashekhar
2answers
I have a HP dv9030us on Vista 32bit and my webcam does not work
if you have tried all the steps mentioned above, try connecting it to a diffrent usb port and then check. if the problem still persist get the cam replaced
Usb ports not working
buy a new mother board or use recovery media after saving files and clean out usb ports
2answers
3USB ports not working
Get a new USB driver from HP website. Yours may have been corrupted.
Web cam pluged in wont turn on
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
HP Pavilion web cam stop working
there are two options:
1. reinstall the webcam driver.
2. sytem restore: select the date where you cam work well
read here to perform system restore: http://laptop-driver.blogspot.com/2008/09/system-restore.html
2answers
Hp pavilion dv9205
built in webcam? if not check your usb plug in mite be dirty or loose
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
