Saitek ST290 Joystick Logo
Posted on Jan 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gaming joystick will not work on combat flight simulator
Saitek st290 pro new. i downloaded software from web site it will workk on keyboard i cannot grt joystick work simulator.
  • goodguysiii Jan 19, 2009
    saitek st290 pro joystick usb connection
Ginko
Level 3:
  • Master 19,396 Answers
  • Posted on Jan 21, 2009
Ginko
Master
Level 3:
Answers
19396
Questions
25
Helped
8074211
Points
55462
There is a fix for several Microsoft combat flight bugs, some of them are about controller compatibility problems.
Download the patch from Microsoft here.
If that does not fix the problem contact Microsoft.
Anonymous
Level 2:
  • Expert 350 Answers
  • Posted on Jan 20, 2009
Anonymous
Expert
Level 2:
Answers
350
Questions
11
Helped
213409
Points
959
When I buy new hardware like a joystick for my computer I sometimes spend hours and days trying to install it myself without any LUCK until I call the manufacturer directly and ask them!
WHAT SOFTWARE DID YOU DOWNLOAD?
FROM WHAT WEB SITE DID YOU DOWNLOAD IT?
I hope this is helpful!
Good Luck!
Anonymous
Level 3:
President:
  • Master 2,559 Answers
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1212887
Points
9283
Go to control panel,click on game controllers and set it up,if it doesn't show up there,You will need to go into your device manager and see if it is there.If not there,you need to un-install and reinstall it.
Anonymous
Level 3:
  • Master 837 Answers
  • Posted on Jan 19, 2009
Anonymous
Master
Level 3:
Answers
837
Questions
Helped
339031
Points
2470
What windows version do you have?
Anonymous
Level 3:
  • Master 716 Answers
Anonymous
Master
Level 3:
Answers
716
Questions
Helped
365427
Points
2094
Try Unplugging The Joy Stick Then Reboot Once You Reach your Desktop Plug The Device Back In And Check For Operation.
Lee Hodgson
Level 3:
  • Master 4,810 Answers
Lee Hodgson
Master
Level 3:
Answers
4810
Questions
Helped
1781855
Points
15941
Hi there
If all the good advice given by my colleagues has not worked then the joystick is faulty or the operating system does not support the joystick, for example, if you use Vista and the joystick was meant for XP, make sure the joystick is compatible with the operating system you are using, if it is, then it could be a fault with the joystick itself.
Good luck
Anonymous
Level 2:
  • Expert 177 Answers
Anonymous
Expert
Level 2:
Answers
177
Questions
9
Helped
57495
Points
368
Hello and welcome to FixYa!,
1) It sounds like a Faulty JoyStick but just make sure it is Compatible with the Game- It might be a Compatibility Issue
Hope this helps --P3NGYJ03
Anonymous
Level 2:
Scholar:
  • Expert 160 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
160
Questions
0
Helped
54540
Points
426
Faulty stick replace it.the only option.
Anonymous
Level 3:
Genius:
  • Master 1,665 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1665
Questions
Helped
979016
Points
3981
Hi Have a look here for its drivers to download.
Anonymous
Level 2:
Sergeant:
  • Expert 378 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
378
Questions
0
Helped
140486
Points
938
The joy stic and the windows verion on which you r using it must be having any particular software conflict on it or the both r not compitable with each other.just check out the sdame joystick at any other pc and confirm the fault.
Anonymous
Level 2:
Sergeant:
  • Expert 221 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
221
Questions
0
Helped
109863
Points
547
First thing you need to do is to install your joystick on your PC. This is relatively straightforward in Windows XP, as it tends to automatically recognise 'plug and play' devices, otherwise you may need to install a 'driver', a bit of software that tells windows how to communicate with the joystick.
In Windows 98, you will probably have to install a 'driver' (check before you buy that it is compatiblewith win98).
once you have done that, you should be able to start the game, go to the 'settings' and check a little box that says 'Enable Joystick'.
Then click 'Game Controllers', which opens a 'wizard' that will show you if the joystick hase been recognised by your PC.
If it has, click 'properties' then 'settings' then 'calibrate' which will take you through the calibration process step-by-step.
--------  you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick.
Anonymous
Level 3:
Genius:
  • Master 2,920 Answers
Anonymous
Master
Level 3:
Genius:
Answers
2920
Questions
0
Helped
934292
Points
7574
The joystick may be faulty or it may not be made to run on the windows version you are running on.try re installing the software and see what hapens but i think its not made to work for your windows version
Anonymous
Level 2:
  • Expert 119 Answers
Anonymous
Expert
Level 2:
Answers
119
Questions
Helped
40478
Points
265
Check to see inside your game if you can see that the joystick is installed..if not check your device manager in the control panel(IF YOU HAVE WINDOWS) THEN GET BACK TO ME
  • 1 more comment
  • Anonymous Jan 19, 2009
    Try unistalling..
    reboot and see if it detects the device.. then if it does when it tries to install point the installation folder to C:\windows\system32 but only after reinstalling the software upon reboot.
    Good Luck
    please note..after uninstalling the software check in the device manager to see if the hardware-being the joystick sucessfully uninstalled itself.
    If you can't fix it using my tips then I have reviewed some of the better joysticks out there and I came up with this one for 29.99 Its a logitech.
    Sorry if you cant fix it.. Remember always spend the extra cash to get a better component that will be compatible and functional.
Anonymous
Level 3:
President:
  • Master 1,990 Answers
Anonymous
Master
Level 3:
President:
Answers
1990
Questions
Helped
909420
Points
6127
Welcome to Fixya! Go into the Control Panel in Windows. There is a Setting in there for Joysticks and Gaming Devices. Click this and Calibrate the Joystick. It should be fine, Just follow the Directions.
Ekse
Level 3:
  • Master 13,435 Answers
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3983479
Points
38023
*Have a look into the windows game pads, do you see it there? calribrate it there, is everything working there?
  • Ekse Jan 19, 2009
    Didn't get a answer to the question.
Anonymous
Level 2:
Sergeant:
  • Expert 367 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
367
Questions
Helped
121764
Points
829
Fully remove the software for joystick by using ad remove programs. Then reinstall the joystick and go into setup for the game your trying to play (assuming simulator) Then look for your joystick and you should be good to go.
Anonymous
Level 3:
Brigadier General:
  • Master 5,158 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
5158
Questions
5
Helped
2064915
Points
15105
Is that a usb connector on it or a serial port ?
Robert
Why won't Microsoft Combat Flight Simulator for Windows 98 recognize my logitech joystick?
click on the joystick and then click on the properties tab
check and adjust compatibility
tick the box and move down the list to win 7 and click that ---apply and ok
it sound slike a compatibility fault or a missing driver for the joystick
What games does this work for
all microsoft flight simulators that accept usb game controllers will recognize ST290 usb joystick.
Microsoft Combat Simulator Doesn't work with joy stick satik 290 pro. nothing works. it worked on xp. doesn't work on vista home.
You need the drivers from Saitek.com.
After selecting download > software, use the "Choose your Product Type) box. Select Joystick and you will find yours listed.
You need to know if you're using Vista or Vista64.
Install them, then plug your stick in. Should then work.
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
2helpful
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Rudder Twist Feature
I have the same game but what you need to do is go to the menu on the hompage of game and go to controlls and disable it. i will post more details later
3helpful
Use of AV8R-01 with Google Maps flight simulator
My blackwidow joystick would not work in google earth, the sim would just crash. I tried a surgestion to remove the blackwidow software and just run it with the ms hid driver. It now works fine, even the throtle and rudder controls.
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Top Saitek Video Game Consoles & Games Experts
Aron
john h
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
