Hello.
I would suggest purchasing a broken Tungsten E2 from Ebay and replacing the screen yourself. Or purchase a screen from:
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PA1995Here's how to remove the display. You need a torx screwdriver.
Using the Torx driver, remove the 4 Torx screws from the back of the case.
Using the case tool, pop the two halves of the case apart.
Disconnect the battery from the mainboard. Set the back of the case
aside.
Pull the black plastic top plate (the part with the on/off switch) towards
you and lift it free. Be careful not to lose the on/off button.
You will see a gold-colored flat flex cable on the bottom part of the
board. *GENTLY* pull up on the right hand side of this cable. This will
disconnect the mainboard from the display.
Replace with the new display and reverse the instructions.
But, if you are not comfortable with this suggestion, here 's Palm's link:
http://kb.palm.com/wps/portal/kb/common/article/832_en.htmlHave you synced your E2 with your desktop ??
Hope this helps.
