To transfer Photos from iPhone to PC laptop, the best way is by using a professional tool like iOS Transfer.
Also you may get more help from this website: Best Mobile Transfer Website
There are tons of ways to transfer photos from iPhone to laptop. Here I will introduce two easiest ways.
Method 1: Use iTransfer
Step 1. Download and install Leawo iTransfer on your computer.
Step 2. Run Leawo iTransfer and connect iPhone to computer with USB cable. The software will recognize your iPhone.
Step 3. Click "Camera" in the left sidebar, and the contents will be shown in the right part of the window. Choose the photos you would like to transfer and right click on these photos to choose Transfer to >> My Computer.
Step 4. After choosing files, confirm the saving route, and then the software will start transferring photos from iPhone to computer. The progress bar in the dialog will show you the percentage of the transfer process, and when the transfer is done, you will get the photos in the target folder on your computer.
Method 2: Use File Explorer
Step 1. Plug-in your iPhone to the computer with the proper USB cable.
Step 2. Once the iPhone has been connected to your computer, you should select the option "Import pictures and videos" so as to find the photos and videos on your File Explorer.
Step 3. Open the folder under the File Explorer and choose your own preferred photos from the folder. Right click on the chosen pictures and choose the Copy option to copy these photos and paste them to your desired hard drive on your local computer.
If you still need more methods, read on this tutorial: https://all-things-about-apple.blogspot.com/2021/06/how-to-transfer-photos-between-iphone.html
Have a try FoneDog Phone Transfer. Phone Transfer User Guide One Click Phone to Phone Transfer
If you want to transfer or backup data to pc or Mac computer, you can use direct data transfer tool, itunes doesn't allow us to transfer the data directly, so when we want to backup or transfer these pics to pc, it can be a little bit complicated.
iphone photos to pc.
Hello,Using iTunes, you can transfer your photos from your iPhone
to your laptop. But if you have tried it and aren't successful. You can use Phone Transfer, which can transfer files between iPhone and laptop. It can not only help you transfer your photos from computer to iPhone easily, but also upload photos from iPhone to computer. The tool is easy-to-use. Though you are a professional or newbie, you can deal with your photos easily.
MobiTrans Transfer
When your iPhone was connected to Toshiba computer, you can see the iPhone recognized as a massive storage device. So you can copy and paste photos directly from here. Or you can use phot o transfer apps to assist you completing such a task. How to Easily Transfer Photos from iPhone to iPhone
You can import photos to your PC by connecting your device to your computer and using Windows Photo Gallery:
Connect your iPhone, iPad, or iPod touch to your PC with a USB cable.
You might need to unlock your iOS device using your passcode.
You might also see a prompt on the iOS device asking you to Trust This Computer. Tap Trust or Allow to continue.
Then, follow the steps in these Microsoft knowledge base articles to learn how to import photos to Windows Photo Gallery:
Windows 10
Windows 8
Windows 7
When you import videos from your iOS device to your PC, some might be rotated incorrectly in Windows Photo Gallery. You can add these videos to iTunes to play them in the correct orientation.
Photos and videos that you sync from your computer to your iOS device using iTunes can't be imported back to your computer.
See more info at:
Whatsapp Recovery
Recover whatsapp photos from iphone
Here's an article as well as a tool to help you transfer photos between iPhone and computer without using iTunes.
http://www.leawo.org/tutorial/how-to-transfer-pictures-from-computer-to-iphone-withwithout-itunes.html
IPhoneTrans is the first solution that makes your iPhone capable of playing any video you have. Owning such an iOS file manager on your desktop, you are now free to put all your classic movies or camcorder recordings, right onto from iPhone or iPad. As the sound and image will be perfectly optimized, that's how AnyTrans excels to give you the best viewing experience.
Step by step tutorial:
How to Transfer Music from iPhone 5 6 to Mac Computer
Thanks for sharing. Usually, users can transfer photos from iPhone to laptop by following steps:
1.Use iTunes. Open iTunes > Connect your iPhone > Select your phone's icon in the Devices list on the left. Click the Photos tab. If you want to sync all your photos, enable the option for "All photos, albums, events, and faces."
2.Use cloud drive like Dropbox, One Drive. Upload your photos from iPhone to cloud and download on your computer.
3.Try some professional transfer tools like iPhone Transfer, which allows you transfer data between iOS device and computer.
Hope this helps.
Howdy, generally speaking, you are able to transfer photos to PC using iTunes, simply sync your data and find the media library on your laptop, but i dig a very smart tool to get it worked. u do not need even installations, simply launch the application, you may get it worked right away. Apowersoft Free Online iPhone iPad iPod Transfer Transfer files between...
You may refer to this guide, it's about how to transfer iPhone photos to computer.
How to transfer iPhone videos and photos back to PC and Mac
An iPhone is not a storage device. Photos take up too much space on an iPhone, so you can transfer these photos to computer then delete them from iPhone. If you are using a Windows PC, when you plug your iPhone to the computer, you can use the AutoPlay or Windows Explorer to import the photos. How to Transfer Photos from iPhone to Windows Computer
It is very easy to do the transfer, you just need to download and install a program iPhone Data Recovery on your toshiba laptop. Launch it, connect your iPhone with this program, it will detect your phone after successfully connected, then scan >preview > recover. The recovery can transfer the ones even deleted off iPhone to PC. In addition, you can choose the ones you want to transfer and uncheck what you don't want to transfer. Read this article to learn more information on transfering photos from iPhone to laptop.
5 Methods to Backup Your Precious Photos on iPhone 5
You can transfer photos from iPhone to computer via E-mail.
1. Tap Photos on your iPhone.
2. Find the photos that you want to transfer.
3. Tap the "Select" button.
4. Tap each photo you want to transfer.
5. Tap Mail. This will open a new message with your selected photos attached. You will not see this option if you have more than five pictures selected.
6. Address the new e-mail to yourself and tap Send.
How to Transfer Photos from iPhone to Computer
Have a try the iPubsoft iPad iPhone iPod to Mac Transfer software, you can use this software to help you transfer your iPhone 4S photos to your Mac computer, this software also can help you move music, photos and many other files from iPad, iPhone and iPod to Mac. http://www.ipubsoft.com/iphone/transfer-iphone-pictures-to-mac.html
You can follow these steps:
- Connect your iPhone with computer using data cable.
- Open Device Manager and find your device.
- Right click on it and select uninstall.
- Wait a moment to refresh it.
- Unplug your iPhone from computer and plug it again.
- Windows will reinstall its drivers.
You can also follow the guide below to achieve it.
If you want to transfer photos from iPhone to computer there are different soltutions for your question, iPhone to Computer Transfer can help you to transfer your photo from iPhone to your computer and iTunes.
SOURCE: how to transfer photos from a PC to an iphone
Ok.. connect your iphone to your computer and itunes will start and eventually an icon of your phone will appear on the left side of itunes.
Click on the icon.. a new screen with several tabs appears in itunes.
Choose photos tab and check 'sync photos from folder' click on the big button with 'new folder' written on it and then navigate (find) the folder that contains your photos.
This is how you add the photos to itunes for syncing to your phone.. It would be wise to edit your pictures to make them smaller (file size) before doing this or you will see a full phone in a very short time.
SOURCE: iphone transfer photos to laptop
so you saved them on your iphones hard drive instead of the photos library?
SOURCE: transfer photos to laptop
You need to install itunes on your laptop so your iphone can sync with itunes and your computer.. this is used to tranfer music to your iphone, transfer photo's and video etc and also to check for new firmware versions/back up your phone.
You can however take photo's from your iphone without itunes if you connect your phone via usb and choose open folder to view files when the dialog pops up after you plug it in.. this has very limited use however you really need to install itunes. Itunes is a free download
