I plug the chair in and the amp meter doesn't move to a charge position ,(internal charger), and batts. don't charge, my friend diconected the neg batt cables from the 2 batts. and we put auto charger 2amps. on each batt. one at a time and they are holding charge, is internal charing system shot, if the amp meter goes will the inter. charging system still work
You will need a off-board charger to charge the chair Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: Jet 3 Ultra, batteries 1 yr old, charge voltage
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Testimonial: "Thanks very much! I wa not sure if the charger was outputting enough voltage to charge the batts, You have confirmed that the batts need replacement"
SOURCE: batt. were left uncharged for
You can't recharge them. they are dead and if you could they wouldn't last. You will have to spring for 2 new batteries. Check with an Interstate battery outlet and purchase 2 U1 sealed batteries for your chair charge before use and charge daily for 20 days to break them in. If you don't use the chair daily charge at least once a week Hope this helps
