I live in brisbane . the blower is 15 months old
SOURCE: New bag wanted for Soverign leaf blower/vac.
Balmers Garden Machinery Burnley Lancs. Tel 01282 453900 have these available.
SOURCE: Toro leaf blower has spark but will not start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You
will need to disassemble the carburetor and spray
with carb.cleaner. Make sure the small screen is free of debris.
(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),
to clean the small portals in carb. These portals can
become blocked. Reassemble and start.
Just let me know if you need further assistance.
Jim
SOURCE: I have a 25cc Craftsman Blower/Vac
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
SOURCE: craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start.
That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms.
Was surprised to find the company went bankrupt in '99.
Another one killed by Asians and fairly poor design.
