Check the belt that is used to drive the auger because it probably broke. If there is no belt check the drive shaft to make sure there is no a broken shaft.
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
I assume the cable to the auger was removed and needs to be re-installed.
There should be a clamp that the cable ran thru, then attaches to the auger
control. Find this clamp on your snowblower, and route it thru this clamp
then attach it to your auger control.
