JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Dec 28, 2012
JVC I art pro ! No picture popping noise blinking blue
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Dec 06, 2007
SOURCE: popping noises and no picture or sound
try replacing the stk's on the deflection board (making sure that all of the resistors on the board are OK and that there are no solder cracks I found one of the jumpers had a bad solder joint on the one I worked on) but if that doesn't fix I have some raw research that might give you somewhere to start :
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jul 27, 2008
SOURCE: I ART PRO JVC 56
You will need to replace the convergence iCs there are two of them they are both STK392-110 Ics you will also need the JVC convergence resistor kit. You can get the ICs and resistor kit at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
kirtec auto
  • 1348 Answers
  • Posted on May 23, 2009
SOURCE: loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
JEfromCanada
  • 59 Answers
  • Posted on Jun 18, 2009
SOURCE: jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Anonymous
  • 12 Answers
  • Posted on Feb 08, 2010
SOURCE: have jvc model HD56G886. heard a pop..picture went
lamp is burned out, reorder one online and install-cheap and easy, the lamp will come with instuctions
1helpful
JVC I Art Pro AV-56WP74. It has a cracked outer screen and I can't find anywhere to replace it. I want to fix the problem.
Question edited for clarity.
If is is the outer clear screen, replace it with a a sheet of Lexan Polycarbonate sheet cut to size. Lexan is bulletproof.
https://www.google.com/search?q=clear+polycarbonate+sheet+cut+to+size
Sears list it but no longer available. After all Rear Projection Televisions are antique dinosaurs. Technology has moved on :>D
https://www.searspartsdirect.com/model/33xrqyx4kj-001758/jvc-av-56wp74-television-parts
https://www.google.com/search?q=jvc+i+art+pro+av56wp74+parts
Service Manual
https://www.manualslib.com/manual/2744485/Jvc-Av-56wp74.html#manual
Can you operate the menu on a JVC 48P777?
It was dumped because it was junk and it is an outdated rear projection DLP. Here are the manuals
Jvc I Art PRO AV-48P777 Manuals - ManualsLib
https://www.manualslib.com > ... > JVC Manuals > TV
Manuals and User Guides for JVC I Art PRO AV-48P777. We have 3 JVC I Art PRO AV-48P777 manuals available for free PDF download: User Manual, Schematic Diagrams ...
2helpful
II HAVE A JVC I ART PRO TV AND ITS SEEING DOBLE
this is a convergence ic problem , u need to replace the convergence ic take the front speaker grill off and the cover for the picture tube , stk392-110
Have jvc model HD56G886. heard a pop..picture went off...blue light over on/off switch blinks quikly. Lamp go bad?
4helpful
Jvc i art pro doe not turn on
Good luck.
Loud popping on jvc av56wp74
2helpful
I ART PRO JVC 56
1helpful
4answers
JVC i art 32" flat screen
Ur video ic inverter board is dead.
U need a new one.
1helpful
4answers
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
