LG 26LX1D 26 in. LCD HDTV Logo
A
Anonymous Posted on Dec 28, 2012
LG 32cs560 wont turn on flashing red and blue light
5 Related Answers
David Low
  • 458 Answers
  • Posted on Aug 14, 2009
SOURCE: My Tv wont turn on LG 327000
If you are still getting audio coming through then there is possibly a problem with the backlights. This could either be a problem with the power supply or the inverter board. You would need a multi-meter to check if you have 24 volts being supplied to the inverter stage. If you have a backlight tester then this would isolate if the problem is faulty backlights. If you can see some resemblence of light on the screen then your problem will be with the main board not processing the signal, try different inputs eg. an RGB source or scart source to see if there is any image showing.
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Nov 06, 2009
SOURCE: lg 26lg30 light blinks red blue wont turn on.
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 14, 2009
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Chi Chu
  • 8457 Answers
  • Posted on Nov 17, 2009
SOURCE: LG plasma just turned off for no reason,
Try unplug,replug for reset that all could do,same prob.must change tha Main backlight Vivdeo board.
Anonymous
  • 2246 Answers
  • Posted on Jan 09, 2011
SOURCE: Hi my lg 42 lcd wont turn on. When power button is
check your tv power supply section
2helpful
2answers
My Nordmende television blue light below screen continually flashing & no tv screen.
Question edited for clarity, your television is 'Nordmende', not 'Norfmende'.
Time for a new one, but try the power reset first as mentioned here.
The standby light on my nordmende tv keeps flashing
JustAnswer https://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ...
1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
How to fix my nordmende tv as blue light is flashing and ...
Ask Me Fast https://www.askmefast.com > How_to_fix_my_nordm...
Its the power supply board, capacitor(s) have gone. Solder on new or replace board. source: 26" lowry tv red and blue standby light flashing and tv wont turn on?
1helpful
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
How to find settings on lg tv 32cs560
Press the Settings button on the remote or touch the Settings button on the front panel. You may download a copy of the manual from http://www.lg.com/us/support-product/lg-32CS560#
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
3helpful
Lg 26lg30 light blinks red blue wont turn on. When unpluged light flashes blue for a minute then turns off
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
