The washer stopped mid cycle and now I can't get it do anything, water is sitting in washer.
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
SOURCE: Washer stopped in mid-cycle and is full of water. I can restart the cycle, but
if it stops at #6 u need to change timer and motor
SOURCE: whirlpool washer LLR9245DQ0 stopped working
Unplug the washer and look to see if the plug is burnt. it may have a bad connection if so you can try to clean the prongs on the plug with a pencil eraser. DO NOT TRY TO CLEAN THE WALL PLUG. Plug it in and see if works. If you don't hear any strange noises through the wash cycle it is ok but,stay close enough to listen.
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
SOURCE: whirpool duet washer
This one is complicated, and could involve drain pump operation or pressure switch hose condition. Behind the bottom panel, there is a detailed troubleshooting guide, and goes into detail about possible solutions to this problem. The bottom panel has three small bolts (facing outward), remove them and the panel comes off, and the guide is in plastic, glued to the back of the panel. Hope this helps.
SOURCE: Whirlpool Duet 9100 will not drain during regular wash cycle
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Hello
& Welcome to FixYa
I Agree,
I don't think it is any other board, I believe the CCU (central control unit)
has gone bad as it keeps on stopping mid cycle. If it was the Motor Control
Board (MCU) then the washer motor should have been causing problems (which isn't
the case) so replacement of CCU will be a great option. Please get back to me
if you have any other questions.
Kevin
