Is the machine siphoning off water as it fills? If it is check the height of the drain hose and make sure it is above the height of the normal level of water that would be in te drum when washing, if the hose is to low the drum will siphon off the water on its own and continue to fill. If the machine is not siphoning off water while filling then you may have a blocked pressure hose or the pressure hose bottle may be blocked not allowing the pressure switch to activate. there may even be a small hole in the pressure switch hose. Check the thin pressure hose that goes from the bottom of the drum to the pressure switch.
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
