Bosch Classixx WFL 2462 Front Load Washer Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer works fine apart from that it does not drain. After the washing cycle it does not drain any of the water away and i have to manually empty the water out of the washing machine, and the clothes are soaking wet.
What can i do?
I will thank you in advace for your help.
Many thanks
  • justme50 Jan 21, 2009
    Thank you for your help. The problem is now sorted.
Barry Coates
Level 3:
  • Bosch Master 3,463 Answers
  • Posted on Jan 17, 2009
Barry Coates
Bosch Master
Level 3:
Answers
3463
Questions
Helped
1406828
Points
12766
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
744
Points
This solution was perfect! I found the drain area, and the filter was clogged with 2 pens, various clothing tags, and a bunch of other stuff - cleared this all out and replaced plug, in less than 5 minutes, was good to go!
3helpful
Bosch WFL 2462 is out of balance during spin cycle
I would think it unlikely that the springs have failed unless they are fractured.It's more likely to be the shock absorber or absorbers. Depress the drum and watch how it settles, if it continues to 'bounce' around its the absorber(s), if it settles after one bounce then it's something else.
Make sure it's levelled ok
regards
w
I have a classixx 1200 WFL2463GB/12 and it keeps bolwing the fusebox in my house.My dad seems to think that it must be the element as it does not happen as soon as I turn the machine on.I then put it on...
I would suspect that it is the element, as if it were the motor, then it would not have done a rinse cycle.
Disconnect the element and try it again, if it does not blow, then this proves it is the element.
2helpful
My bosch classixx 1400 express washing machine has become very noisy when draining water, it never used to be. Any ideas?
If it is only noisy when draining the water, then could be something stuck in pump.
There should be a filter located at the bottom front right of washer behind a cover.
Unscrew anti-clockwise to remove and clean, and look inside the pump opening as well to see if anything is stuck there.
2helpful
2answers
1helpful
2answers
Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Bosch WFL 2462
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight.
Possible u didnt connect well after your pump job or ........
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
