My Kenmore was off balance and we would have to stop and start three times to get it to cycle through. (it would stop during the filling of water) well now it just turns on and hum. When any buttons are hit it just beeps three times but status does not change. No error codes are being displayed and it does nothing except sit and hum when plugged in.
SOURCE: kenmore oasis elite he
Have you tried leaving the washer unplugged for at least 30 minutes? The manufacturer recommends, first unplugging the appliance for this duration to reset the control board. In some cases this will correct momentary glitches. If this does not resolve your problem, you will need to inspect your drain pump. The "ld" error code is a Long Drain problem which is usually an indication of a clog in the drain pump or drain line, or a failed drain pump. This model washer has two pumps, I believe. One is a recirc pump, the other is the drain pump. The drain pump is below the wash tub on the RIGHT hand side (as viewed from the front of the washer). The way you access the pump is by tilting the washer backwards and working from underneath, or by removing the back panel of the washer. In order to safely tilt the washer, however, you will need to drain the wash tub. The easiest way to accomplish this without bailing is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. You will need to empty ALL residual water in order to remove the drain lines to inspect the pump. If you do not, be prepared to mop up a lot of water. Your washer has one of the largest wash tubs available.
There is also a tech sheet inside your washer with all the error codes and recommended troubleshooting advice. You can access the tech sheet by locating the release tabs along the front of the washer where the top cabinet meets the front of the washer. About 2 inches in from each side you will find a tab in the seam. Use a putty knife and push straight in while lifting up to release. NOTE: This may require some muscle to do. Once you have the top free, hold on to the washer lid BEFORE you lift up the top or the lid will fly open. The tech sheet should be attached between the front washer case and wash tub.
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
SOURCE: Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Kenmore Elite Oasis HE top loader has LD error code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
