I downloaded the XP driver and it keeps telling me to plug in the microscope, which is already plugged in!
Before you run the program, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
SOURCE: Intel Play QX3+ Microscope
Try a different computer and install the QX3Plus application (for Win 2K-XP). If it works okay, then completely remove (uninstall) it from your Dell 4600 and clean up the registry of unusable strings (try Advanced Registry Optimizer, its a free download). Then do a clean QX3Plus install BEFORE you plug in the USB cable. If the QX3 did not work on a different computer, the QX3 is faulty and maybe you should look at the QX5 as a replacement. The QX3 was discontinued at around the turn of the Century. However, if you are only missing the SPLAT; try locating the green button at the lower left corner of the image screen, it produces drop-down dialog boxes to splat screens. Good Luck!
SOURCE: qx3 miroscope
This worked for my QX3 on my Vista computer!
Instruction for installing the QX3 Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
SOURCE: QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
Step 2. Download and install the QCODINSTL.EXE software from:
SOURCE: vista driver for Intel QX3 Microscope
SOURCE: I HAVE A 1501 INSPIRON DELL LAPTOP WINDOWS 98 IS
I have used the QX3 microscope without issue on a windows xp machine
here is a link with more info
http://www.intel.com/support/intelplay/qx3/sb/CS-016015.htm
