Toshiba Satellite L755S5216 Intel Pentium Processor 156 Display 4GB DDR3 Memory PC Notebook Logo
Posted on Dec 25, 2012
Disc read error - Toshiba Satellite L755S5216 Intel Pentium Processor 156 Display 4GB DDR3 Memory PC Notebook
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
187
Points
5
This usually means you have a bad hard drive. Also could be sectors of your hard drive that is bad as well. This problemcan be fixed by simply buying a new hard drive and installing it. it is rather simple. Good luck!
3helpful
Getting disc read error
THere are a number of problems that can cause a disc read error. The lens can be damaged or very dirty. The motor that moves the les could be stuck or damaged. The disc could be dirty or scratched. Or the disc format might not be able to be read by the player. Do you try more than one disc? Are you trying different types of discs? like store boght discs and recordable discs. Some players wont read mp3 or cd-rw discs.
Disc read error
Disc Read Error is mainly due to worn-out,dirty lens and it can also appear because of the disc that you have inserted in your PS2......
Try following to get rid of DISC READ ERROR:
  • Clean your PS2 lens:
Watch this video first
This will help you in cleaning the lens.You can also clean your PS2 lens by some lens cleaning DISC.Make sure not to touch lens with your hand.
  • Clean your DISC:
Watch this one to clean your DISC
Thank you!!!
2helpful
2answers
Cannot read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide...
2answers
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
1helpful
2answers
Game will not read disc. Starts and then says error
1helpful
Wii error reading disc
If Wii gives Error reading disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Disc not reading
2answers
The Wii will not read the disc
"Unable to read disc" error happened today for the first time on my Wii. I positioned it horizontally and tapped on the top while it was reading a disc and it started the game. This temporary solution might bring you immediate, but probably not long lasting satisfaction.
Error reading disc turn power off
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the Exisitng Disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
4answers
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
