I have a 4 GB transcend pen drive. it is showing write protect. How can i remove. the same.
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel auto run operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Hi
Virus or Trojans can run some process that keeps running in background. This will not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. re insert the Flash drive or Pen drive, dont open it and dont cancel Auto-
Run operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
You can download a software called recovery tool from the transcend website which is exclusively for transcend flash drives.. insert the drive into your system and run the application..
click this link for visiting transcend website..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
you can also try formatting using command mode.
Goto start--> run and type cmd..
the command window will open now . Type format X:
(X being your flash drive)
Pen drive is write protected and the file system is also removed
password protection
