It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected. Before going to buy any parts
directly. This is list of refrigerator problems,
which is normally faced in refrigerator. -------------- ------------ ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html These will help. Thanks,.
Go through this troubleshooting help links.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making
ice?
Water Overflows in Ice maker
and freezes inside?
How to replace Ice maker
assembly?
SOURCE: Westinghouse RP423 Freestyle fridge cooling failure
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
SOURCE: Westinghouse RJ275M 194l fridge with top 81l
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
