Error code e41
SOURCE: frigidaire affinity atf7000es1 E41 code
check to see if the door stike is not broken on door if good and you have changed door lock asm you have a bad control board
SOURCE: I am experiencing an error
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
SOURCE: Fridgidaire Affinity ATF6000ES1 washing machine
Checked the internet for manuals and found one that had a blowup of the parts sequence. Also found instructions at the manufacturers site for trouble shooting and repair.
SOURCE: I have an Frigidaire Affinity
Hello
& Welcome to FixYa E41
error indicates that the problem is with door lock assembly, it is displayed
when the control board thinks that the door switch is open. To solve this
problem you have to remove the door lock assembly and measure the resistance of
the PTC. If it reads open then the door lock assembly needs replacement
however, if the reading is around 1500 ohms then replacing the control board is
recommended repair. Please get back to me if you have any other questions. Kevin
SOURCE: Frigidaire Affinity washer (LAFW3511KW0) with
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
Hello phrainer3 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
