Bought a new unit. The old unit was a surround sound system in which the previous owner removed the speakers. I wasn't aware of the problem but found out that it would not allow it to play on Dolby 5.1...It would only play DVD's on channel 2, therefore no english etc. Thanks for your help!!!
you have probaly changed audio tracks on the dvd,just go to menu and audio,and pick another audio track,a lot of DVDs come with more than 1 audio track (im talking the actual DVD not the player
I dont know what model and dvd brand you have but would like to assist you. Go to dvd setup menu and check audio settings, make sure to set on stereo. Problem will be resolved.
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
erm,, when you say you cant hear voices clearly. do you mean that they seem to be a little lower in "obviousness" than they should be or are they way down ther as the background level is so much higher.
1. a little lower means you need to bring the trebble up and the bass down and bring up the centre and reduce the surround , this is basically tuning the sytem to your room.
you also need to check the dvd setting for audio out to ensure that the settings for the audio on the dvd are set to 5.1 ( if the little black spare connector is connected to your dvd player) or else set to stereo for "normal " palyback.
2. if the voice is way down compared to background sound track.
are you using an amp for the bass channel, this may need to be turned down. or the thing that looks like a spare connector on the end of the cable going to your cd5 unit is not correctly installed. can you tell me what the set up is.
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
