I was goin to throw this away, but thought should check the internet for value first
Don't throw it away! Bulova have a good reputation. It ma not be worth much, but you have the serial number and the 14k probably means it's 14 carat gold. 14 carat old is the highest quality used for watches (18 carat is too soft for everyday wear) I used to work for Shackman and we made watch cases and bracelets for the major brands such as Omega.
Trysearching for Bulova watches on eBay then looking at 'completed listings' under 'advanced' after you search for some idea of value.
Regards, Andy
SOURCE: old Jaeger-lecoultre woman's wristwatch
I would be happy to help. The problem is it is impossible to determine the value without seeing the watch(condtion is paramount). your best bet is to ship it Registered mail return receipt requested that way you have proof that it was received. I would think that that $5,000.00 insurance would most probably protect you. email me if you have any questions Donald McPherson CW www.finewatchmaking.com
SOURCE: BULOVA WATCHES
Most watches have the gold content engraved inside tha back cover. Open carefully!
SOURCE: American Waltham pocket watch
Ebay often has these for sale; one I also inherited in an 18K gold 'hunters case' (closes from and back) even though perfectly working after a retired jeweler brought it back to life, turned out to be more valuable for its case than anything else. I've seen similar at swap meets/flea markets in plated cases for as little as $70 and still ticking.
SOURCE: Bulova 14k Solid Gold woman's watch. Swiss 17
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
SOURCE: I have an antique bulova
Hi!
You can't tell actually the date when it is manufactured by the serial number of the case metal.
However if you manage to open the backside and look in the inside there will be markings that will help in the dating of the watch.. Look at the image below for example
as soon as you open the back case there is a symbol (pointing by red arrow) that was being used that time for dating.
From the table below.
Dating at the early 50's are different. 2 digits printed on the backcase signifies the date manufactured.
L indicates 50's
M indicates 60's
N indicates 70's
so if you see a 2 digit stamped on the backcase for example is L2
then it means it is made on 1952.
You will not find this information unless there is a 2 digit on the backcase or you will find a geometric symbol inside the case of your watches.
I hope this helps
Please accept if you find this solution helpful
Thank you for using Fixya.
Alp
