Brand new buld..red light blinks indicating a full charge and does not work!
SOURCE: Home Cafe GT300 Black and Decker- won't work, brand new
I have the GT300, and it also started having problems with the 14oz and cream loight s blinking. After trying the unplug and replug thing I gave up, I came back to it the next day and it started working again so I just kept running it over and over until I got it to fail again when I opened the lid and put a pod in to make a cup of coffee. It wouldn't work again so I unplugged it and set it back up and held my hand on the lid and applied a little pressure and it started working again, so far with a little preesure applied it still works. My guess is there is a switch that dosen't make as well as it should, you don't have to hold the lid down during the entire brewing cycle just long enough for it to get started. Good Luck
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
SOURCE: charged lawnmower, now won't work - Black and Decker 24V cordless
battery is toast...sorry:o(
SOURCE: charger not charging have 2 new chargers neither 1
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
