I have a Mitsubishi 65 inch dlp. 2006 model. It has started to become quite fuzzy with fast movement scenes. Very low hours; about 1500 over 6 years. Fuzziness becomes apparent in dark football jerseys of running player or action movie scenes.
SOURCE: Mitsubishi 65809 65 in Blue color and center screen fuzziness
Projection TV's use a cooling fluid around each of the 3 CRT's that the
light has to shine through. Over time, it will grow a bacteria in
the fluid (just like sunshine on the ocean) and turn cloudy. The
blue CRT is most subject to this. You need to have the fluid
replaced, which can be a messy job better done by a pro, but many have
done it themselves. If you are interested, I'll go into the
details.
Might want to replace the convergence amps while your at it.
Hope Ya Fix It!
SOURCE: Mitsubishi medallion 65" hdtv
the dm module power supply is developing leaky capacitors and will eventually cause the set to not come on at all. this may also be causing the snowy picture if you are useing the digital tuner. The dm module will require repair to resolve these issues.
