Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
SOURCE: my sole f83 treadmill is
Hello there,
When the treadmill remains in 0% incline and then comes up with a message showing elevation error, it is quite clear that there is a problem with the treadmill and the problem is related with the mechanism that controls the elevation of the treadmill.
The mechanism responsible for the elevation of the treadmill is some hinges that are located in the lower front part of the treadmill. They are weak and cannot lift up the treadmill anymore.
The solution is for you to have them replaced, then you turn on the treadmill, then you press the incline control key and it will increase in % this time.
Hope this helped.
Goodluck
Elect_Comp
