SOURCE: No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
SOURCE: HOW TO PROGRAM REMOTE
unplug the main harness from the unit for 2 min, then plug it back in and press any button on the remote, the parking lights should flash when a new remote is programmed
SOURCE: how do you program a second remote.
I didn't, but I thought that maybe I could get a answer without joining something.
