Old pump little use for its age completely cleaned out and put back together pulled stuff out of the fuel for the first day and now fuel clean it won't run any longer than a minute and will start first pull after it dies there is also no change in sound before it dies
Ensure you have oil filled up to the edge of filer hole where the oil barely drips out then start if she continues to stall remove the yellow wire connected to the oil alert sensor restart the motor while she is running reconnect wire back to the sensor if ahe cuts off replacement on oil alert switch is recommended.
Yep, what Phil said about the oil Level. If it's right, then the wiring or the little control timer box is bad
Check that the fuel tank is venting properly, sounds as though the tank is not venting therefore creating a vacuum that the carburetor cannot over come. Try running the engine with the fuel cap loose to see if that alows the engine to continue to run.
SOURCE: why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
