Televison & Video Logo
Posted on Dec 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My daewoo model dsj-4710 turns on but goes right to standby need help finding out whats the problem
It starts on standby and when i hit power it turns on for about 5 seconds and shuts off and goes back to standby...i need to know whats the problem..please
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Dec 23, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715855
Points
48227
Main power supply which has the standby supply with it--look for those pesky puffed up filter caps.
5 Related Answers
Anonymous
  • 1139 Answers
  • Posted on Oct 26, 2007
SOURCE: Sony Big Screen TV Not Powering On
This looks like a problem with the High Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I hope this helps,
Thank you,
Shuttle83
onefunldy
  • Posted on Feb 02, 2008
SOURCE: TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Anonymous
  • Posted on May 28, 2008
SOURCE: Intermittent lamp turn off
your lamp is fried just change it i did the same to mine and it works just like a charm
Anonymous
  • 19 Answers
  • Posted on Jun 20, 2009
SOURCE: TV works for 5 min then shuts off and power light blinks green
check your sleep mode...
Anonymous
  • 125 Answers
  • Posted on Mar 24, 2010
SOURCE: I have a 51 in. Sony model kp-51ws520. when I turn
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
2004 rear projection daewoo tv problems
No value used, no one wants this old technology anymore.
I Have 2004 43' inch Daewoo model DSJ-4710CRA will power on but cuts right back off any fixes?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
NO PICTURE ONLY SOUND
just ask the daewoo service center to repair your tv
Tv power on and sutdown after a series of bips the green light change to red and stay red
Tv power on and sutdown after a series of bips Problem with the Daewoo DSJ-6000LN 60 in. Rear Projection Television tv power on and sutdown after a series of bips the green light change to red and stay red
I am looking for the part for a daewoo part number DSJ-LF10 do you know where i can order it?
http://www.encompassparts.com/products/?4959500001
lamp model is know with three different names or numbers: 4959500001, DE40LP, DSJ-LF10.
Standby light comes on but TV won't when turned on
I am having the same problem. Have you had yours repaired yet?
2helpful
Daewoo projection tv...looking like 3-D
if the TV you are talking about is the DAEWOO DSJ-5510CRA.. u having a
convergence problem.. i hope this can help u in some way.
1helpful
Black screen
you need to pull the back of the tv and check the fuse. some of the tvs of your kind have a fuse that could pop.let me know how or if this works at [email protected]
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
