Samsung Gravity SGH-T459 Cell Phone Logo
A
Anonymous Posted on Dec 12, 2012
Unlock my SGH-T459 SAMSUNG FOR FREE - Samsung Gravity SGH-T459 Cell Phone
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Dec 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
4924
Points
22
You can't get any Free Code if your Mobile is locked by any Service Providers. If it is Locked so, Unlock your Samsung SGH-T459 Gravity Phone by Clicking this site http://www.onlinegsmunlock.com/. Follow the Instructions:-
1 - Switch ON your Samsung SGH-T459 Gravity without any SIM Card.
2 - Compose : #7465625*638*CODE#
5 Related Answers
Anonymous
  • Posted on Feb 06, 2008
SOURCE: samsung SGH-x475 t-mobile unlock code
sure the unlock code goes as follows... *2767*6903557610011172#
after you do that it will seem to shutoff but leave it and it will then open up to working screen... you will have to enter this code each time you turn off the phone but it should work,,, if u have any questions... e-mail me at [email protected]
Anonymous
  • 261 Answers
  • Posted on Jun 05, 2009
SOURCE: I need free unlocking codes for samsung E590
hai, I agree with venkat. But i also found the site called http://www.mobile-unlocker.com/.It's also having the code and instruction for samsung mobile.
Anonymous
  • Posted on Feb 08, 2010
SOURCE: FREE samsung sgh-t239 sim subsidt unlock code
Whats the code required to unlock the samsung SGH-T239 Phone IME # 011841 00 030683/101
Anonymous
  • 949 Answers
  • Posted on Feb 14, 2010
SOURCE: from where I get samsung sgh-t459 usb driver
They do not make one for your phone, and they do not have you phone setup to work with the samsung pc studio.
So the only thing you can do is this, and maybe pictures.
  1. Insert a microSD memory card into the memory card slot located on the left side
  2. From standby press the Menu key
  3. Select Settings (9)
  4. Select Phone Settings (3)
  5. Select USB Mode (5)
  6. Highlight Mass Storage and press the Save key
  7. Plug one end of the data cable into the handset's power/data port located on the right side and the other end into a USB port on the PC
  8. On the PC, open My Computer and double-click on Removable Disk (Hint: it will be assigned a drive letter and, depending on system configuration, may not be the only Removable Disk present)
  9. Using Windows Explorer, copy and paste (or drag and drop) MP3 files from your PC to the Music folder seen under Removable Disk
Testimonial: "as its the only option i have these is very helpful thanx"
Anonymous
  • Posted on May 17, 2010
SOURCE: how to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
2answers
Forgot unlock password for samsung gravity sgh-t459 tmobile
phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
I want to sumsung sgh t-459 unlock code.Imei is 35306103834021703
To unlock Your samsung Phone get the unlock code from the site Simpleunlocking.com and get Free Unlocking instructions from the site Mobileunlockguide.com/samsung-sgh-t459-gravity and unlock it easily...
How to openline for samsung sgh t459 for free
hi codes are the best method to unlock Samsung sgh t459 from network to get codes visit theunlockspot.com here they ask you the network name to which your mobile is locked then the imei number of your mobile .finally they send you codes to unlock your mobile.
How to unlock samsung gravity sgh-t459
There are lot ways To Unlock the Phone ,but Unlock code is easy and Correct way to Unlock the Phone from Network Lock,You need to specify the Current Network Lock and Country and get the Unlock code at here Onlinegsmunlock.com
and Unlock it,then You can use it any GSM Network ...You can follow the instructions below and Unlock it step by step..
Samsung SGH-T459 Gravity Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung SGH-T459 Gravity mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-T459 Gravity mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-T459 Gravity with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-T459 Gravity will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-T459 Gravity shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-T459 Gravity.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-T459 Gravity is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-T459 Gravity.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-T459 Gravity.
2helpful
3answers
I need an unlock code for my samsung gravity model number SGH-T459
You can get the unlocking code from http://www.mobileunlockguide.com/samsung-gravity .This site provides the unlocking instructions at free of cost.Through this you can unlock your mobile easily.
How do i unlock my samsung gravity sgh-t459 for free
1. Turn on your Samsung Gravity without the SIM card inside.
2. Now type in #7465625*638*UNLOCK_CODE#
Where UNLOCK_CODE represents your 8 digit unlock code. (Warning: Entering more then 3 incorrect unlock codes, may permanently lock your phone!)
3. If everything worked, your phone will say “Network Lock Deactivated
You can get unlock code from your service provider. Hope this helps
I want to un lock my samsung sgh T459
Visit www.unlock-free.com, select your phone product and follow instructions. It absolutely free.
You could also try www.mobileunlocked.com/index.php, and follow instructions. But you would be charged for the service rendered on this site and you can get your money back if it does not work.
Take care and don't forget to rate this.
2helpful
Free unlock code for samsung gravity t-mobile cell phone
Hi, I recently unlocked my Samsung T459 (Gravity). I can share my unlock code and instruction to see if it will work for you only by request. Contact me: [email protected]
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
